The Node
List pane is part of the SignalTapII Logic Analyzer
Setup tab, Data tab, and Advanced
Trigger tab. In the Advanced Trigger tab it displays as a
separate pane. In both Setup tab and Data tab the three columns Node Type, Node Alias, and Node Name display within the tabs and
not as a separate pane.
Displays a list of pre-synthesis, non-incrementally routed nodes
available for use in the Advanced
Trigger tab.
Node Type—Displays
the node or bus type, such as an input pin or state machine.
Node Alias—Allows
you to create an alias for the node or bus. You might create a node
alias, for example, to shorten a long node name. A node alias is
useful, for example, when a node name is very long and/or is
truncated.
Node Name—Displays
the name of the node.
Note: The node order is the same between the Data tab and Setup tab, except for duplicated nodes in the Data tab. Making
changes in one tab produces the same changes in the other tab. Nodes cannot be duplicated in the Setup tab.
